Bought 2003 Subaru outback in 2007, engine went at 269,000 miles. In June 2013. Wife like the car so much and the body has no rust, so I put a rebuilt engine and transmission in it. So the rebuilds approximently 30,000 miles.
Need to replace struts all the way around, running gear has 268,000 miles got the car at 50,000 miles. So any recommendations on brands, Minnesota weather is a factor, and the wife wants a good ride
The trans fluid has approximately 30,000 miles on it, no the a.t. light does not blink 16 times, no dents in the pan, they better have changed the filter, yes I do check the fluid at idle and on level surface.
Thetransmissiona and engine are rebuilds, 30,000 miles on each. RResently and randomly the a.t. light comes on then car lurches forward well driveing after about 40 miles. Shut it down let it sit for 1 to 5 minutes good Togo. Fluid is normal level, cooler seems good. It also runs rough when your at a stop light with the brake depressed. At a stop light if I shift it into neutral rpm drop about 200rpm. Any advice would be greatly appreciated
