yortyarg
Everything posted by yortyarg
  1. Need to replace struts all the way around, running gear has 268,000 miles got the car at 50,000 miles. So any recommendations on brands, Minnesota weather is a factor, and the wife wants a good ride
  2. Transmission was rebuilt because of oil leaks and wanted to match the rebuilt engine and transmission with same miles from the get go
  3. The trans fluid has approximately 30,000 miles on it, no the a.t. light does not blink 16 times, no dents in the pan, they better have changed the filter, yes I do check the fluid at idle and on level surface.
  4. Thetransmissiona and engine are rebuilds, 30,000 miles on each. RResently and randomly the a.t. light comes on then car lurches forward well driveing after about 40 miles. Shut it down let it sit for 1 to 5 minutes good Togo. Fluid is normal level, cooler seems good. It also runs rough when your at a stop light with the brake depressed. At a stop light if I shift it into neutral rpm drop about 200rpm. Any advice would be greatly appreciated
