powderhogg01
Everything posted by powderhogg01
  1. yes the vehicle was warmed up and in idle, in the neutral position. there will be a few days until I can get those codes. I considered running the seafoam treatment, however I think I will hold of for now. I will do that, then pull the TB and iacv and give that whole section a real thorough cleaning. I picked up some MAF cleaning, but I am holding off on it, as the maf looked fairly clean on the inside.
  2. I did the mentioned fixes. changed the plugs, replaced the fuel filter and the pcv valve, I also cleaned the throttle body a bit where I could reach without rmoving it. I think I will pick up the gaskets and pull the TB off and give it a proper cleaning. I noticed a big difference. The car now has ok acceleration and seemed to do a lot better on the big hill near my house. I have been driving my other vehicle as a storm has us burried in snow. I will do the code reading when it warms back up a little bit. I noticed broken 3 way connect from the pcv valve, so I will replace that before I drive it more. I checked the transmission fluid, it was a thin gross brownish red color and smelled slightly burned... It also had too much of it, I removed the excess and the issue of no power seems to be fixed. thanks for the suggestions, hang with me for those codes.
  3. I am new to the flash style codes, but will do it a few time to insure I am getting the same results. Hoping for a simple fix, and not something terminal..
  4. Hey guys, I have picked up a '93 subaru legacy. When I purchased the car it ran a bit rough but seemed in decent shape. It has been a little over 2 months and the vehicle is getting worse. Here is whats going on.. When you go to accelerate up a hill or in the morning, even with the foot mashed to the floor the power take off is not there, the vehicle barely moves at all. when you come to a stop it will sputter and occasionally it even stalls out completely. When this happens it starts right back up, but the power take off issue remains. I just learned how to get codes from the vehicle and I will do that next and report what is going on, however in the mean time I was hoping some of you guys have seen or heard this issue and may point me into the right direction. I first thought the issue was transmission related, but I am no longer leaning on that side of the fence, this morning when I left my house to drive up the hill to my work the car started fine, had a rough idle.. very low at times, then when I had the accelerated all the way depressed it barely moved. the engine was not revving or anything, just a very low idle and light forward movement.(you could walk faster then the car was willing to go) during this no lights or sny of the sort came on, it was as though the vehicle had entered limp mode. So today I am going to change the plugs, pvc valve, fuel filter, and the air filter. this is a non turbo legacy. I bought the car a a safer alternative for what my girlfriend was driving as I live in a mountain area which has a lot of bad snowy nights. I can not give her the car to drive around until its running well and I know its not going to leave her stranded.. as winter is fast approaching I need to get this fixed and fast. If I can answer any other questions in regards to the car and its no power issue please let me know, I am an experienced mechanic, but have very little experience dealing with subarus, at this point I wish I would have bought the jeep I was looking at, as I know jeeps.. thanks in advanced my subaru friends
