tpetriep
  1. I have a 2000 Outback with 56k miles and the 4cycl engine. Here is the problem. About two months ago, the A/C started blowing warm air at low speeds or idle. Once you get going 45mph, it gets back to normal cold air. It would not do this all the time just on occassion. Then this past weekend the car started over heating. At idle the car runs hotter than normal but does not over heat. Once you start going down the road it overheats fairly quickly and starts blowing warm air out of the A/C. I don't know if or how the two problem could be related. Last night I changed out the thermostat, and then changed the oil and air filter as part of normal maintance. I did not notice the oil having any water in it and the coolant than came out when I changed the therm. was clean. Any ideas on why the car is overheating? Thanks! TP
  2. I have a 2000 4cyc. Outback with no owners manual so I don't know if this is normal or not. Everytime I use the Keyless entry system the horn sounds once to open and twice to close. Is this normal? Second, I have noise. It sounds like it is coming from the front end. The interval between the noise increase as speed increases. It sound like like a "thud/ deep clicking" sound. I have taken the wheels off and looked around and have had no luck stopping it. Any ideas? Thanks TP
