NoOneBetter
  1. Update: Decided to upgrade to Group N transmission mount for added performance and also to see if this would fix the wobble feeling. After installing the mount there was still a slight wobble but less than before and mostly in first gear. Seems like the mount helped a little but did not completely alleviate the issue. I also decided to install the driver side axle and did not notice any ill effects from that axle so seems like the issue is isolated to only the passenger side axle.
  2. I recently picked up a pair of these and so far have only installed the front passenger side and I have a slow speed wobble coming from the axle most noticeable when in 1st and 2nd gear. I also saw that it came with some information regarding vibrations from the axle and lay the cause to a worn transmission mount. Has anyone seen this before and is there any merit to their statement? I have a 2nd axle that I have yet to put in for the driver side since I am thinking about pulling the installed axle out and purchasing OEM remans from subaru or the HERI HD axles to avoid any more problems.
