Wakeup666
  1. What do you do with the wrenches? I've used the clamps
  2. But then I put tension on the belt and they spin
  3. It's a timing issue. I've retimed it and now I can't get the cams to not move when I'm putting the belt on. I get one side fine and move to the other side and then everything moves agai. But with the ecu. I've heard of people having the 96 motor on the 97 ecu. And the fuel rail I've replaced the injector gaskets I've replaced every gaske. Thanks guys! pointing me in the right direction is a big help. Thanks again!
  4. All the vacuum lines are hooked up. The big ones and the small ones but still runs like there's a big vacuum leaks but I can't hear anything hissing
  5. Hi guys. I'm doing a motor swap in my buddies 97 legacywith a ej25. I got a 96 ej25 motor in and it runs but is surging at low idle. Then eventually will die. I had the motor out and re did all the gaskets. I am stumped. Can anyone help??
