subaru forever
Posts posted by subaru forever
hg and cluster.my cluster went out and still can not get new one working.so out $$$$ for car.my junk it
still nothing.going to junk
figured.it out.ground problem .which little screw would be a ground .thinking one of the 4 than can loosen up?
- 1
checked all fuses.relays.what i did notice when taking out old one a small strip of then like aluminm foil.the strange thing is the back of cluster where it gets pluged into.the plug makes no contact with metal.like it just sets in there.so maybe a ground wire put on?and where should i attach it to on cluster
the bad cluster and new one.seem to work for 97, the 99 cluster is different front and back.the title says and vin shows 99 .how did the old cluster work if the car is a 99 ? i am all confused?
i posted before that i had.a 98,found title it is a 99,but still can not get it to work.seems like plug -in is different.?the new cluster and old one are the same.? seems like i lost a piece ?any help
no damage to plug-in
can not show pic.mine could be 99 not 98
does anyone have pic of 98 cluster.of back side where plugs go into
the fuel gauge reeds full and temp gauge works
seems like the 97 and 99 are the same.on the back side.but the plug from car seems to small or needs another piece
still no luck.getting cluster to.work.checked all fuses.and relays.even put in old cluster.back in.the tach worked before.but nothing now.any help
i have both here.the 97 and 99 both are the same where the plugs are and front
not sure how to post pics
seems to be missing a larger piece for the center connection?
now seems to be battery and alt.to cold to mess with it anymore dam junk
the good cluster is from a 97 outback.same plug -in.everything the same
do all 4 screws have to be in .like ground.
recheked everything.99 outback limited edition.automatic.2.5
replaced cluster.working.all bulbs.now no dash lights.or speedo or tach.any help
my speedo cable quit working.thinking maybe way to fix or replace? 99 outback wagon.2.5,276,000 miles
cluster problem.99 outback
Posted
grounded it and still no go.any suggestions
