1chersman
  1. I read that about the CD player as well. It seems to be working fine (rarely use it anymore). I did eject the 4 CDs that were in the deck with no problem. As for the battery, its from August 13 and has tested fine from 2 separate parts stores. The reason I believe it's a parasite is the car cant sit for more than 24 hours without needing a jump. I'm also on my 3rd battery in 3-4 years (once I ultimately replace the current one). The alternator also checks out per parts store check. I don't know what else it could be
  2. I'm working on my wife's 06 Legacy GT. We've got some sort a parasitic electrical drain going on. Using my meter, I found it's drawing right at .1 amp, but I cannot locate the source of the draw. I've yanked every fuse and relay and still can't locate any source. The only way I can get any movement in my meter reading is to disconnect the main screw terminal fuse under the hood or disconnect the top positive battery terminal. ( which appears to feed that fuse). Any insight would be greatly appreciated.
