Sir Moist
  1. So.. Ea82-- GL .. My blades are swinging to far. I know the newer model there's a plate you lift up and replace the little plastic elbows. On my 87 I don't see what to do.. Could some one Yoda me? please... May the force be with you. Always.
  2. Thanks for the great info... Almost as good as, The Uplift Mofo Party Plan.
  3. Well, I didn't see an adjustment on the linkage. Just a shaft and a cotter pin. All mounts seem tight. I think.... I might... Cry.... Its so hot I can't blame it on the rain.. Yeah yeah.. Think I might just be hosed..
  4. Perfect I'll check the mounts.. Thanks.. Soon as I have less then a 12 hour day at work.!!!
  5. 87 ea82 gl wagon.. So moist.. Thanks so far yeah.. I'm going to see if there is an adjustment.. And hell yeah .. Hole and a bungee ... Keep them coming , most appropriate, and appreciated. Thank again.
  6. Ok... I know.. New transmission, or rebuild. But,.,,, does any who have a trick up wherever they keep em?? 4 wheel low on my moist awesomeness, slips into the neutral, in between 4 high 4 low. Trick anyone in having it stay in low without the inopertone time of the slip??? Thanks ..,
