Everything posted by darkwingduck1
- 1997 legacy outback 2.5 l
No they were the single electrode, and I have changed them out , now I am looking at the fuel injector for number 4 cylinder and when I messed with it yesterday the code came on right away. How hard is it to replace the injector in these engines and is there a difference between OEM and aftermarket injectors
New plugs , new wires they used bosch double platinum plugs and a good wire set, since then I have changed out the plugs twice and am still getting a P0304 code which says it is #4 cylinder misfire, the only thing I haven't done is change out the injector, and I did get a code one time that was listed as an injector, that was several months ago , and now am wondering if the injector is starting to fail.
The car went in for a tune up , afterwards I started noticing that it ran rough and was getting codes. Finally have it down to one code that pops up repeatedly which is #4 cylinder misfire . I replaced the plugs again , and moved plug wires around and even put a new ignition coil on. Still getting the same code and I am wondering if it might be the injector starting to go bad, I have 259k on this engine and it doesn't use oil or run hot. The car will sometimes go 80 miles or so before the check engine light comes on and other times just a few miles and it comes on . The engine is a 1996 2.5l and has run fine before all this started.
