TheLander45
  1. The fuse hasn't blow again, from what i understand if you hook battery connections backward or jump the car with the connection made wrong you could blow the fuse. And I believe that was the case. Where are the other fusible links located at? I was only aware of the one in the fuse box under the hood.
  2. Looking to buy a 1995 Subaru Legacy Outback. But upon inspection the fusible link was blow, I replaced it and When i turn the car to "acc" radio, dash lights, and etc. turn on. When I turn it to "run" everything turns off and I get a battery dashlight. Then if i leave it like that in a minute or two i hear a mysterious clicking coming from the dash. Bad ground? Bad wiring? Is this not worth the trouble.?
