Crawfordbuilt
  1. When I start the car with everything off, then hit the ac button, I can hear something engaging. Then if I hit the button to "off" then back to "on" , I can hear it engaging again. You mentioned both lines being hot , and the sure are hot , one a little less than the other . Like I said when I tried to charge it , it wouldn't take a drop. No condensation on lines at all. Like there was a blockage or something .
  2. 2010 forester blowing hot air only even with AC button on . Thought it might be low level issue with refrigerant. When I hooked the kit up with the can and gauge the system was a little low but wouldn't accept any of the can. Not a drop. Is something stuck closed?? I tested the kit on another car and it worked, I guess that rules out a problem with the kit . HELP!
