nitpikker247
Everything posted by nitpikker247
  1. The "Odd" wearing is only on the Outside of the Driver side. I switched the pads from Passenger side to Driver side and vice versa. Same problem "only" on driver side. The New rotor and caliper are the 2nd set I've tried! Not the pads. The Pads fit nicely; not jamming or wiggling loosely. Thanks All
  2. I have just replaced my REAR disc brakes. (Rotors, Calipers and Pads) Passenger side is OK! Drivers' side, however... The outer 1/3 of the New rotor is not being contacted by the New Pads. I figured I would switch the pads with the other side, being there was only a few hundred miles driven. No Change.Then I made sure the Slide Pins were moving Freely.They were. Figured it was a Defective Rotor. Exchanged it. No change. Then I figured it must be a defective Caliper. So I exchanged that! STILL, NO CHANGE!! When you look at the Rotor, The Inner 2/3 of Is wearing properly. The outer 1/3 still shows the Brand New Machined Surface with some Oxidation. No Wear. A N Y S U G G E S T I O N S ? ! Exasperated
  3. I have just replaced my REAR disc brakes. (Rotors, Calipers and Pads) Passenger side is OK! Drivers' side, however... The outer 1/3 of the New rotor is not being contacted by the New Pads. I figured I would switch the pads with the other side, being there was only a few hundred miles driven. No Change.Then I made sure the Slide Pins were moving Freely.They were. Figured it was a Defective Rotor. Exchanged it. No change. Then I figured it must be a defective Caliper. So I exchanged that! STILL, NO CHANGE!! When you look at the Rotor, The Inner 2/3 of Is wearing properly. The outer 1/3 still shows the Brand New Machined Surface with some Oxidation. No Wear. A N Y S U G G E S T I O N S ? ! Exasperated
