Everything posted by 99 legacy decel hell
Decel grind from hell
So will the axles from my stock tranny work on the new tranny from an rs 2.5
So no video sorry wont work on my phone
Here's a video drove it home today sound got real bad now more of a constant also pushed clutch in and it keeps going and can't stop with out reall bad shuddering even tho not in gear
No sorry ment when in gear will post a video tommorow if I can figure it out
There is fluid tires are all the same #3 the sound did go away when clutch was pushed but starting this morning just constantly grinding also comes and goes not a constant grind for when the clutch is depressed #4 there is little to no sound when accelerating. #5brakes are fine does not matter for sound. #6 I will check for motor mounts did not think of that had it up in the air deffinitly in the front not nessesarily tranny/dif #7 it's a manual not sure if possible will post vid tommorow driving work van lol
I found the full swap at a local junk yard but it has 280k on it:(
What cars will the tranny swap from ?
Also in neutral free revving it's silent
It deffinitly sounds like a problem in the tranny, or dif until it kept going once clutch was engaged. Alsoo put some punctuation in there haha sorry.
Help it's so bad as soon as you let off the gas it grinds, usually I just push in clutch and it's all quite. But today it did not, now I need to fix it but what is it I jacked up the car and it is coming from the front end for sure more of a click when there's no real weight on it no idea what it is do I need a new tranny or front dif. I just bought the car and it's my first Subaru kinda bad start haha it's a 99 legacy l wagon 5 speed
