mtnpat
  1. The rear main seal was definitely leaking before a little bit, but was leaking worse AFTER I replaced it that is for sure! I know now I should have left it alone. So any tips for installing a rear main seal correctly, given the crankshaft is smooth and un-grooved? What's the trick? On the oil separator plate, can I just re-seal the factory plate or do I need a different one? Thanks Again! -mtnpat PS: Never mind, I found this: http://www.ultimatesubaru.org/forum/showthread.php?t=113361&page=4
  2. Getting ready to pull the motor in my 07 Outback basic 5-speed and could use some help. I did a clutch job as well as timing belt/pulleys and water pump replacement at about 90k miles. At that time I also replaced a slightly leaking rear main seal. I am at 125k miles now and have a pretty good leak going. I am going to pull the engine soon and replace rear main seal again along with valve cover gaskets (had oil in spark plug wells at 90k). On an 07, should I reseal the oil separator plate for good measure? Replace it? What about oil pan and cam seals, or anything else? Thanks! -mtnpat
  3. OK, motor is in! I did pull motor back out of engine compartment and made sure clutch alignment tool was centering disk and with pilot bearing as well as it could. Then I just got in front of motor by myself (previously was using two people, one on each side of motor) and man-handled motor into position and got it started onto shaft. Then some small nudges on the 22mm crankshaft nut on front of motor to make sure splines were aligning, and it found its way home. Then a slow pull in using the tranny to motor bolts and she was done. Aligned motor mounts, exhaust and set her in position. Thanks for your help. -mtnpat
  4. I did NOT center the pilot tool as you suggest, I just let it hang. Going back out to see about doing it right. Makes sense, as I remember after installing clutch and removing and re-inserting pilot tool, it was a tight fit. Seems like I am not even getting the shaft starting into pilot bearing. Be back in a few. -mtnpat
  5. 2007 Outback 2.5 basic Removed motor to install new clutch and now need to re-install engine. Any tips on how to get the motor and manual tranny back together that last inch? I have a pretty good alignment angle between the engine and tranny, the two lower studs are in their holes. I can't seem to get the input shaft from the tranny into the clutch and back of the motor (pilot bearing). The tranny is out of gear so the input shaft will spin, I was hoping it would find its own rotational position by itself so the splines line up. I'm thinking its the tight tolerances between the tip of the tranny shaft and the pilot bearing. Tranny is jacked up some, motor mount studs are clearing the frame by about an inch. Any tips? Thanks! -mtnpat
  6. Never mind I got it. I was able to remove it with this tool and pressing on the inside of the yellow plastic part of the quick disconnect. Not sure how you would be able to get it with a metal disconnect tool, this because you have to get over and past the first ridge in the fuel line to push in on the plastic part and release the connector from the second ridge. With the plastic tool, I was able to force it into the connector and get it to come apart. -mtnpat
  7. Can't figure out how to undo the fuel disconnect on my 07 Outback. Which part am I squeezing, pushing, pulling, etc? I assume the yellow plastic part. I have tried squeezing with the tool below but it did nothing. Will this cheap rump roast tool do the job? Thanks -mtnpat
  8. Not overheating. I thought possibly something was obstructing the exhaust system causing it to get hot, or maybe the engine running to rich and dumping extra fuel through and into the exhaust, but not the case the engine is running fine and there are no check engine lights. The clicks and ticks are constant, while driving and after you turn it off. I doubt this is normal.....haven't heard any others do it, and the last one I owned didn't do it. Car is not new....over 1 year old with 20k miles. Too loud to ignore.
  9. So you think it is related to a loose shield or shield bolt, and not necessarily a heat (overheat) issue?
  10. Has anyone else experienced this? 07 Outback basic, 5-speed, 20k miles About one week ago the heat shields around the front of the exhaust system, directly under the engine started popping and pinging....making that 'I'm hot, metal expanding/contracting' noise. It does this all the time, whether driving in stop and go traffic, or cruising along at 65mph on a 70 degree day. I could be driving down the interstate and as soon as I come down the off ramp and pull up to a stop I can hear the exhaust making noise. Or driving to work on a cool morning and pulling into the parking garage, shut the engine off and listen to it ping, ping and ping some more as I walk away from the car into building. It is pretty loud and sort of embarassing. I don't believe anything is missfunctioning, the engine seems to be running normally and the exhaust system does not seem abnormaly hot. I am going to take it to the dealer as soon as I can, but for now was wondering if anyone else has experienced this and how it was fixed?
  11. I did a dumb thing and left my key in the aux position and drained the battery on my 2007 Outback. A quick jumpstart got the engine going with no problem, but now I am down on horsepower, especially at low RPMs. All electrical systems seem to work fine, no check engine lights, etc. Does the computer have to re-learn proper fuel mixtures and timing or something?
  12. Getting ready to change my plugs to try and cure the dreaded Subaru pinging, and was wondering how many steps colder I should go? I don't know what is in there now, but just for arguements sake let's say they are BKR5E-11. Should I try BKR6E-11 or BKR7E-11? Try one or two steps colder to try and cure pinging? THANKS
  13. No CELs have ever come on, and the dealer has never seen any bad codes or whatever. As drxflyboy said, I hope it is just a defective knock sensor. I think whether the dealer I take it to actually hears the knocking or not, I will insist they change the knock sensor.
  14. Well, I have 2 Chevys and 1 Honda that run fine on the same gas that I use in the Subaru. I shouldn't have to take special measures for the Subaru, unless that is the Subaru is an inferior vehicle. If that is the case I will get rid of it. But to answer your question, I have tried other brands of 87 and it didn't help. The only thing that helped was running 91.
  15. thanks FJ for the tips. yes, gonna take it to a different dealer. Will report back when/if I get it fixed.
