Thanks!! It seems like it is this one:
http://www.ebay.com/itm/Clutch-Pressure-Plate-and-Disc-Set-VALEO-52254803-fits-86-89-Subaru-GL-1-8L-H4-/301781009065?hash=item46438cc2a9:g:TQwAAOSwT5tWMAXF&vxp=mtr
It look like it is the same pressure plate like mine!
I have the 225mm X21 splined clutch, and doesn't find it. Looking on E-bay, and most is the smaller plate or 24 splined. I need a whole kit, and are lost in the clutch problem issue. Does some one have the part number, or can give a link to where It is?
Thanks, It was the from the tire! I had it in for balancing and checked in the "tireshop" . Adjusting the steering (toe-in toe-out etc). I byed a CV-axle/joint, and installed It. Nothing happened before I changed the front tires tho the back. Then at last, the vibrating was gone!
It is from -86 EA81. I have checked the tires and rims. I hear a crackling sound when set it in gear, lifted up. It is from the right side. It is more vibrating under load, just like you say. Vibrating much. Ok, Do you know what year/model of leone? Thanks for the answer.
Hello!
New member here! : )
I wonder if Leone cv- joint fits in the Brat front ones? Are the back driveshafts same as the front?
When I drive in 80km/hours, the steering wheel starts to vibrating.
I am from Scandinavia, and have little education in english, so sorry if I am not spelling so well.
