beau83
  1. I want to swap the EJ20 Engine and 5speed Manual Gearbox in my Subaru Outback/Liberty Wagon 1999 model, it has selective AWD. I want to replace it with an EJ20 Engine from a Subaru RX Impreza Wagon 1998 model, 5 speed Gearbox with only 2WD. I have added some photos of both 'main engine wiring harnesses' which might help.. The 99' OUTBACK/LIBERTY main engine harness has "1x14 pin(brown) + 1x19pin(white)" plugs, while the 98' RX IMPREZA engine has "1x6pin(white) + 1x8pin(grey) + 1x16pin(grey) plugs. Im wanting to know if there is a 'conversion plug kit' available for this swap or do i need to get it re-wired? I cant swap engine harnesses because most of the plugs on the other end are different. I also noticed that the ECU plugs(located on passenger floor) are also different on these 2 models, any information/help with this conversion would be great. Also how do i confirm what size the engine is 2.0l-2.2l- 2.5l? They are both EJ20 engines and im pretty sure they are both Australian models (i bought them both in Australia) Thanks in advance BEAU83 I am putting a EJ20 engine and gearbox out of a "1998 SUBARU RX IMPREZA wagon" into a "1999 SUBARU OUTBACK/LIBERTY wagon".... I have tried changing the Intake Manifolds with Engine Wiring still attached but the Intake Manifolds are different in size. Attached Thumbnails
  2. just a quick question for anybody who has information on this, iwant to swap the EJ20 Engine and 5speed Manual Gearbox in my Subaru Outback/Liberty Wagon 1999 model, it has selective AWD. I want to replace it with an EJ20 Engine from a Subaru RX Impreza Wagon 1998 model, 5 speed Gearbox with only 2WD. I have added some photos of both harnesses which might help. The 99' OUTBACK/LIBERTY engine harness has "1x14 pin(brown) + 1x19pin(white)" plugs, while the 98' RX IMPREZA engine has "1x6pin(white) + 1x8pin(grey) + 1x16pin(grey) plugs. Is there an adaptor plug that I can purchase or do i need to get something made up or swap engine wiring harnesses (which i am trying to avoid doing)?. I also noticed that the ECU plugs(both located on passenger floor) are also different on these 2 models, any information/help with this conversion would be great, also how do i confirm what size the engine is 2.0l-2.2l- 2.5l? They are both EJ20 engines and im pretty sure they are both Australian models (i bought them both in Australia) Thanks in advance BEAU83 I am putting a EJ20 engine and gearbox out of a "1998 SUBARU RX IMPREZA wagon" into a "1999 SUBARU OUTBACK/LIBERTY wagon".... I have tried changing the Intake Manifolds with Engine Wiring still attached but the Intake Manifolds are different in size. Attached Thumbnails
  3. I want to swap the EJ20 Engine and 5speed Manual Gearbox in my Subaru Outback/Liberty Wagon 1999 model, it has selective AWD. I want to replace it with an EJ20 Engine from a Subaru RX Impreza Wagon 1998 model, 5 speed Gearbox with only 2WD. I have added some photos of both harnesses which might help. The 99' OUTBACK/LIBERTY engine harness has "1x14 pin(brown) + 1x19pin(white)" plugs, while the 98' RX IMPREZA engine has "1x6pin(white) + 1x8pin(grey) + 1x16pin(grey) plugs. Is there an adaptor plug that I can purchase or do i need to get something made up or swap engine wiring harnesses (which i am trying to avoid doing)?. I also noticed that the ECU plugs(both located on passenger floor) are also different on these 2 models, any information/help with this conversion would be great, also how do i confirm what size the engine is 2.0l-2.2l- 2.5l? They are both EJ20 engines and im pretty sure they are both Australian models (i bought them both in Australia) Thanks in advance BEAU83 I am putting a EJ20 engine and gearbox out of a "1998 SUBARU RX IMPREZA wagon" into a "1999 SUBARU OUTBACK/LIBERTY wagon".... I have tried changing the Intake Manifolds with Engine Wiring still attached but the Intake Manifolds are different in size.
