barrington
  1. what will a radiator replacement cost? My antenna wont retract - repair or replace.
  2. Forgot this problem: The little lever that pops open the gas tank cover is frozen tight. Could it be rust? How could this be freed up.
  3. A big thank you to all respondents. Picked up the car today after a new timing belt and water pump was installed. The mechanic said the old belt was on its last legs and whover recommended replacing it now was giving good advice. You can get close to "catastrophic engine damage" without realizing it. The same mechanic replaced the brakes and advised bringing the car back around 70,000 miles for spark plugs and wiring overhaul. The owner of a local Grease N Go who i believe was a former Subaru exec flushed the radiator and changed transmission and diff fluids. Car runs quieter and smoother and next week gets new tires, BFGoodrich Travelers. As a cancer patient I need reliable transportation and you all have contributed to that. Life saving advice indeed.
  4. Thanks for your responses everyone. I can see getting the timing belt-water pump kit right away but the gasket thing looks expensive. What kind of cost can I expect from each of these repairs?
  5. I have a 1999 Legacy GT wagon, runs nicely, with just under 60,000 miles. How much longer can I expect before major repairs are needed?
