Pacosquared
  1. I have changed out the timing belt along with idler pulley, tensioner and the water pump. The car wants to overheat when I drive it. Nothing in the oil. No white smoke. I lifted the front of the car and did the squeeze and fill method to get air out of the system. I put the radiator cap on because it started to overflow and then when I checked it with it off the top and bottom hose was caved in. I took of the radiator cap and they went back to normal. Any ideas? I am going to take out the new thermostat and try the boil test.
  2. I pumped a few squirts of starting fluid and no change in the turning over so I assume no spark? I will check the timing belt. Is there a place to go to view owners manuals/ engine schematics? Thank you.
  3. i have a 1995 Legacy L 2.2 SFI? While driving it it suddenly got Hot and water spewed out the drivers side in the engine compartment. From where? So I refilled the radiator with about a gallon and then continued on when suddenly it it stalled. I checked and filled the oil. It was down 3/4qt. Now it only turns over and will not start? Where do I start? Thank you.
