Volcman95
  1. Hahah no kidding never buy flywheels from oreillys lol
  2. It runs!!! Thanks for all the help guys. I ended up haveing to go to a junkyard and find a flywheel then i measured how far the timing marks were from the 0* mark then transferred that to my flywheel and timed it with that.
  3. So i tried to find the three hashmarks for the timing but cannot find them for the life of me i cleaned off the flywheel even though ut was lretty clean to begin with as i just replaced it with one from oreillys. But i can only find the numbered timing marks
  4. So i did try the starter fluid thing and it didnt work because i went back throught manuals and i believe i set the timing to the wrong mark after all so ill try that tonight and let you guys know what happens thanks for all the help
  5. Yes i put the engine at tdc on the number one cyclinder on the compression stroke than set the rotor to the number one point on the cap
  6. Hey guys so i checked everything that you suggested and cleaned out all connectors and everything. I also replaced the coild cuz it was old and looked a little leaky. I got one little gurgle from the exhaust right when i tried to start it and then nothing again. I rechecked all the timing and it still looked fine except for when we re did it the closest we could get ut was a little under half a tooth off but didnt think anything of it.
  7. Is there any way to test the transistor on the coil bracket? Also where would i go to buy a new bracket ive looked around and cant seem to find anything.
  8. Okay ill try those and get back to you guys thanks for the fast responses!
  9. Hey guys i recently purchased my 91 loyale 4wd 5 speed and pulled the engine to fix its many oil leaks and do head gaskets and such. Well i put it all back together and it just cranks but wont turn over i have checked timing replaced cap and rotor cleaned out all the plugs i am getting fuel compression and a slightly weak spark but cant figure out why its weak! Thanks in advance for the help!
