bnedziwe16
  1. Gooday I have a very similer problem on my 2003 Legacy B4. In the morning the car starts with no issues but if you leave it idle for a few miniutes sometimes it cuts on its own. Sometimes it can drive for a few minutes and when you stop or put it in reverse it can shut. The behaviour is random but what i have noticed for sure is if you step on the gas flat foot it cuts off and if your were already in motion and you remove your foot on the gas it turns on like evrythn is normal. Also if it cuts off, it will not start again it keeps cranking for a while then it may start. The MAF has been said to be the suspect and removing the MAF connector when the car is on causes it to cut immediately most of the time. Somtimes i start it whithout the MAF and it starts normaly but the engine check light will be on. If i connect it the engine check may go or appear then it cuts. what could be the cause so i get it fixed knowing?? Help will be much appricited
