gbowne1
  1. I have had others ('95 Legacy Sedan) where in this mode, they were off KOEO. With the exception of Batt. (weak battery & alternator).
  2. trying to figure out one of several things. Vehicle:1995-1997 Subaru Legacy Wagon L w/AT & AC Condition: KeyOn EngineOff Self Test Beeps / chimes: 5 times These bulbs are all still on after system/bulb test completes: Check Engine AT Oil Temp Oil Battery Brake What could be going on here?? Recently had a P0400 code. needed some EGR/ BPT work. Code Cleared. May still have clogged pipe(s), head, etc. CEL (nor do any of the others) do not appear after the engine started. Recently had a Drain & Refil of Dextron III ATF Brake Master Cylinder replaced recently. Front Brakes 25% (4mm) Rear: 7mm Other work that needs done: Rad Hoses all belts Front brakes Axle Boots Power Steering Pump rebuild (leaks) minor engine leaks (needs new gasket set)
