janewolff
  1. oops should have looked at the date on that one. it has a new knock sensor that i replaced a few months ago (housing was cracked). i also replaced the o2 sensors, plugs and wires, ignition coil, all of the exhaust which was crazy rusty and new the MAP sensor. it's idling better but dies when i give it gas. i'm going to check the PCV next
  2. i was having the same problems with my forester (2000), even replaced many of the same parts that you did and it's still not running. mine started out hesitating occasionally, usually after the engine was hot but it finally died all together. the MAP was also covered in oil and looked pretty beat up so I ordered a new one, i'm hoping it fixes the problem. how is yours running now? did you check out the PCV? just curious how it's going as it sounds like the same issues at my forester
