Dawes
Posts posted by Dawes
Hi i posted a while back about having heater issues in my 1992 loyale. So i put the oem thermostat in and in made quite the difference my cars temp barley got above the operating temp now it gets to almost halfway on the gauge. So the heater works a little bit better but its still not hot... now im looking for input on where to look next, maybe heater core? it gets warm (keep in mind its 4 degrees where i am.) but just not hot. thanks!
also looking to lift my subaru... and all of them that i see lifted have bigger wheels... how could i go about getting bigger wheels?
i use 10w40 in summer and 10w30 in winter. ill have to check it out with the cooling system last winter i burped it several times and flushed heater core getting same temp out of both hoses and it was still cold...
just did some reading on an old post on the heater and gonna try getting a thermostat from the subie dealer, and checking out that fresh air inlet line behind the glovebox and see if that helps if you have any other ideas let me know.
Yeah i replaced the cam tower seals with OEM ones when i did my headgaskets. itd probably help if i had them machined and did a better gasket job. didn't cut any corners on the headgasket itself though. One more question? my heater is awful, car doesn't over heat, fresh thermostat and blower motor. but sometimes when i shut down the car it makes a bubbling noise...? any ideas on solving my heater issue and does the bubbling correlate
So i have a 1992 loyale, i replaced the head gaskets last winter. and im starting to get scared that im gonna have to tear it apart again. It leaks very slowly from the camshaft housing and valve cover, and has a tick when the motor is cold. My question is should i grow a pair, rip it apart and fix it or should i look at other options?
Hi I have a 92 loyale (with a/c) I have had problems with the alternator ground wire having a bad connection... And I'm guessing you all know how that turned out. Fixed that and I had bad alternator symptoms once again. So my question is.. After I test the alternator I'd like to replace the wiring is that something I can buy at an auto parts store.. Or should I just add new connections and hope it won't happen again? Thanks!
Curious about that 6 cylinder...? I don't know a whole lot about these engines so I'm just unsure where I would buy the drivetrain and how much it would be? Or which one to choose
So back to the swap... The ea82 is about 85hp. If I end up doing a swap I'd like around 150-200hp, so I'd probably need to do transmission, steering, suspension, and ecu... So what id like to know is what would be the best route to go for motors and parts... Or if it would even be worth the trouble
Id love to just save up and buy an sti but... They don't have a whole lot of ground clearence and I do a lot of off road driving. Now most people would just say buy a truck... Don't like gas trucks don't want 14mpg and don't want to deal with the spoob that comes along with buying a cheap diesel. And my loyale does just fine off road
I'm a mechanic so if be able to do all of the stuff on my own. I don't know though is it really worth spending a lot of money on an n/a ej I mean I'm not sure how much power that would really add...? input?
It's a 92 loyale ea82
On the edge of selling the car or swapping it... Is it worth it? Price range estimate? I already know mostly everything would need replaced
Yeah that's true could end up being more costly than it is now
And what would be the best and adaptable to my transmission...
Hi I have a 92 loyale, looking for advice, so my clutch is going out heater core is bad and my rack and pinion is bad. Now no matter what I do I'm gonna have to fix these issues before I sell it or rip it apart. but my idea is to possibly swap an ej in. Or buy a truck. So if I do go with the ej where can I get one and about how much and how much more for one with a turbo? Thanks
Any other ideas why it's not getting hot?
Couldn't find clr but I flushed it again and got the air out of the system and hoses are the same temp. But the heat is only working decent on drivers side floor and on settings 2-3 and setting 1 does nothing
Also I tried flushing out the heater core worked decent for a few days now one of the hoses isn't as hot as the other again
I'm not seeing levers moving but they are all covered up and I can hear the door opening and closing just so damn cold to work on it or drive it and I have no clue haha it's -10 in idaho
Already tried the heater core and flushed it just for good measure. How do I check the blend door?
Hi I have a 92 loyale and having heater trouble and I've done everything I can think of to get it to work and it still won't.. Wondering if there is a heater control valve and where that might be
Heater problems (Update) help 1992 loyale
Posted
Sorry took so long to get back but I got a new thermostat now the car heats up.... but if I leave the heater off than turn it on full blast it's hot for one second then cold again
