Orion
Everything posted by Orion
  1. Good info guys, here is where it is at: In park: No click or power draw while trying to crank it. In neutral: Clicks once and draws power (dash lights dim slightly) when key is turned to crank position. Jumping the starter trigger wire directly to the battery: Click is much louder.(motor turned ever so slightly on first try, then stopped) So the starter is bad again, or the motor is seized, right?
  2. 1994 Legacy. Starter was replaced a few years ago, and the car has not been used much since. Sometimes it would just click when trying to start. If it would not start, jumper cables would remedy the problem. Now it wont do anything at all when trying to start it, even with jumper cables Battery is good Automatic trans The "trigger" wire to the starter is reading 0 volts when the key is turned to the cranking position. I do not believe that the starter itself is bad, I just think its not getting the 12v signal to energize the solenoid. My best guess: Starter relay is failing/bad? Help! Where is the relay located? Under the dash near the steering column? Could it be something else? I have attached pictures that should be of some use.
