Subaru cars
Everything posted by Subaru cars
  1. Changed 02 sensor .front .erased code .check engine came back on heater control circuit this code was not on before .any help 2000 forester.a/t
  2. 93 impreza sedan fwd.cruise control not working location of Thermo switch
  3. Seems that the relay is grounded out .with ground wire so will check .ground and relay. both fans running all the time is ok.but not necessary.
  4. Refresh my memory where is the sensor that control the fans when temp goes up.both my fans are on all the time
  5. Yes after 2 hrs figured it out.flush out etc... The cable is bad. That lets cool or hot air in.vent was open.radiator .thermostat good.so if anyone has problem .check vent door first
  6. Dumb question .which does thermostate go point up or down
  7. Strange thing is a ground wire from relay under the hood.thinking. Is wired to run both fans.so problem has been there awhile
  8. Yes thinking that also will check before buying radiator.temp control works but cold or hot still very hot inside.finally getting warm around here thanks
  9. Bought a 93 FWD impreza .does not over heat .both fans are on all the time. Temp gauge reads half way.but gets way to hot inside car even with temp control set to cold .any help or suggestion.! Coolant is full and good
  10. Are the front axles the same front wheel drive and awd ? Automatic
  11. Not checked that yet.why all the codes.? Replaced ejectors .
  12. Replaced IAC.plugs wired.maf.wires.crank sensor.code reads misfire 1-4 .any help
  13. Leaking from rear of motor.on cross member.checked heater hoses.and all other hoses .any other possible places to look.seems to leak more when using heater
  14. Checked vin 3 places.the last vin # is correct.I have no led but roll pin for odometer .the 99 will not work.plug ins are different the old cluster is the same as the used one I have
