justinpajski
  1. i did check the fluid in trains actually looks really good, tires are all the same size/ rear right tire seems to be wearing on the inner side all others seem to be fine. as for the lights flashing i do not have any on.. but thank you for your input much appreciated
  2. alright please someone help me out!! i have a 99 legacy sus limited 30th anniversary 2.5, well to start out i am having trouble with ALOT and i cannot for th life of me figure out whats wrong and soon I am just going to drive it into a lake!!! whats going on: when staring on coldstart idles fine and warms up good (most of the time) but sometimes it idles high then low, and the heating control lights flicker (sometimes). when i accelerate it seems to shake not to bad but you can for sure feel it then some times it drives fine and does not shake at all.... it also pulls (sometimes). it also every once in a wile seems to rev up when pressing on gas and doesn't really want to move, getting very shitty gas millage to... what I did/replaced -plugs and wires -temp sensor and thermostat -brakes and rotors -fuel pump -checked for vacuum leaks -checked tranny fluid -ran seafoam threw it -oil and filter change -replaced ground wires for battery -clean mas air flow sensor and throttle body
