snowmaker
  1. well I Thought I update you on what the problom was. to help others .when I installed engine oil pump coupler must have been missalined and broke oil pump inner gear. installed new pair of gears gaskets to auto box. so take care when installing engine Gearbox
  2. Hi I go with the Thermostat First. Its an easy job . all you need is a large container to catch the coolant and a 10 mill socket and a extension bar just undo the two housing bolts with container below then let drain. pull gently the old thermostat with pliers. I just take the old thermostat out for a few days and see if still overheats. Refill and blead System with coolent.
  3. Hi just rebuilt 99 Engine. Think I Have a Knock sensor Lying arround The engines Changed in 99 I Have the Early Model so if you Check the plate should tell Engine Type
  4. Thanks Sports . I Think it must be something not allied Propally. If anybody got a Diagram Would help. Thanks Snowmaker
  5. HELp! I Just Installed a Rebuilt Engine into a Outback. But Have no Drive . I seem to Have no Oil Pressure. I Did change the Fluids and did dusturb the torque Converter, But Think all is Lined up Ok. Sugestions!!
