Islandbike27
  1. Owned this legacy for a couple of years now and have changed the fuel filter before. Bit after changing it this last time, it won't run anymore. Fires up no problem, runs for a few seconds, and then starves out. Pump is cycling on during ignition, and I do have high pressure fuel coming out of the filter (installed correctly). It's obviously a fuel problem.. Possibly some sort of air lock in the injectors? Is there a bleeder nut on the rails that I am missing? I have replaced the pump relay, and the coil and still having the same problem. Could it be possible that the ECU is causing the problem? 97 Legacy L AWD
