ggwa9mm
  1. #15: PU B/UP fuse... although I can't determine what PU means (assuming b/up means "back up" (lights?))
  2. Excellent! 2nd fuse I pulled. Thanks for the help!!!
  3. Was beginning to wonder if I was alone on this... Google Searches, forum searches, all turned up the code description (which I knew). I will go through the fuses asap and post results (hopefully good results). Thanks!
  4. Evidently I can't attach a txt log attachment, and cannot paste its contents either. If anyone needs info to help decipher this that may be in the log (like Volage: 14.2V) let me know.
  5. Also good to note: have driven over 150 miles since over the course of 3 weeks.
  6. Hello, I jumpstarted another vehicle with my 2015 Legacy, and immediately got a CEL with Code P0560. I know it means low system voltage, but Alternator is working, Battery is good, connections are good... I have tried to clear it, but keeps coming back after a few seconds. Freeze-frame log below if needed or helpful. Any help would be appreciated! Thanks,
