sadiedogwalk
Everything posted by sadiedogwalk
  1. Thanks! The fuel line that was recently replaced was leaking into the engine. This time it is leaking around the fuel tank.
  2. A month ago smelled gas really strong inside my car. Took to the shop and they said the fuel line was leaking in the engine. Prior to taking it into the shop when I tried to start the car it would crank but not turn over until 2-3 tries. Had fuel line replaced. Thought it would solve the cranking but not starting issues but it came back. I was due to have the spark plugs and fuel filter replaced so I did last week. Next day same starting issue. Usually happens after the car has sat for about an hour or two. Cranked but would not start until third try. Just got back from driving it and I see something leaking from around the gas tank. Pretty sure it is leaking fuel. So very frustrated and don't know what could be causing this. What should I have the shop check? Fuel pressure, obviously check leak. Not even sure if the starting issue is related to the fuel leak issue.
