henry_rap
  1. Help! Where is the ABS relay on a 1995 Legacy? Is it located at the hydraulic unit or somewhere else? Also - where can I get a new relay? Thanks!
  2. 1995 Legacy - the ABS light came on and stayed on this morning. Also, the hydralic unit in the right front of the engine compartment is running constantly with and with-out the engine being on. Any ideas? Thanks!
  3. It looks like I need to replace the back catalytic converter. The pipe leading into it rusted and broke away. Also, the pipes on the "Y" pipe leading into the front catalytic converter are rusting. I don't see any holes, yet. I think I might replace the system at least to the 2nd catalytic converter. Any recommendations on where and what to buy? Any comments on the Magnaflow system? Thanks. 1995 Legacy - 129,000 miles.
  4. My 95 Legacy has started to drip oil. It looks to be coming from the front of the engine. When I look under it the oil is collecting and dripping from where the lower raditor hose goes into the motor. Any ideas of where to look? The car has 101K miles on it. Thanks
  5. Thanks Cougar. I do notice an occasional coolant smell. I will have it looked over by a pro. I take it by your comment that the heater core is not a fun thing to replace.
  6. I getting luke warm heat not hot and the windows are fogging up something fierce. Any ideas of why the windows are fogging up? Thanks for the help.
  7. Do I need to drain both the radiator and the block when replacing the thermostat or can I get away with draining the radiator only. I can't flush the system right now but I think I need to replace the thermostat. Thanks.
