Dgrinnell
Everything posted by Dgrinnell
  1. Hey guys thanks for all the help. Just did the compression check and all are at 148 to 150 except the pass front. Not getting anything on that one. What's my next step?
  2. Do you have a guide for doing valve adjustments? Or is there another post somewhere I can follow
  3. iTrader: (0) Send a private message to dgrinnell Find all posts by dgrinnell Reply With Quote Alright guys I'm just picked up a 93 legacy wagon awd for cheap for my new dd. It's running rough and seems to not have the power it supposed to have. Ithe run rough at ideal and while running up in rpms. I've already put new plugs and wires and nothing changed. I also pulled the codes which we 14 16 and 17 which says fuel injectors. I can pull the passenger front injector wire off and have no change same with olug wire.but when I pulled the others it will die. I also switch 3 and 4 injector with no change .I'm at a lost here as I don't know much about subarus. I've also changed the fuel filter. I'm sure someone else has had this issue before so I'm looking for some help.
