YellowstoneYeti
  1. I noticed today that my clutch fork is cracked and looks like it will fail soon. It's on a 98 Legacy Brighton wagon. Has anyone ever tried to weld one of these? I can't tell if it is cast or not. I would prefer not to have to pull the motor or trans if possible. Anybody got an easy fix?
  2. I've got a 98 Brighton wagon with 2.2L, 5 speed, and 208K miles. I've had the car since 66K miles and it has been well maintained. Recently it has developed an intermittent starting problem. About 98% of the time it starts and runs normally. The other 2%, it will start normally, run for about 5 seconds and die. Then I can crank and crank and it will not fire. If I leave it sit for a few hours, it starts and runs fine. It seems like it loses spark or fuel or both, although I can't confirm either one. I thought perhaps it was flooding so I tried depressing the accelerator while starting but had the same results. There is no CEL and my reader does not show any codes. It has happened 3 times in the last 3 weeks. The common denominator has been sub-zero cold on all 3 occasions. The first time I thought maybe I had some water in the fuel, but the symptoms are too similar I think for that to be the case all 3 times. Obviously, I don't feel like I can trust the car to not leave me stranded in extreme conditions. Does anyone have any ideas on where to start looking? Thanks for any help you can offer.
  3. I've got a 98 Brighton wagon with 2.2L, 5 speed, and 208K miles. I've had the car since 66K miles and it has been well maintained. Recently it has developed an intermittent starting problem. About 98% of the time it starts and runs normally. The other 2%, it will start normally, run for about 5 seconds and die. Then I can crank and crank and it will not fire. If I leave it sit for a few hours, it starts and runs fine. It seems like it loses spark or fuel or both, although I can't confirm either one. I thought perhaps it was flooding so I tried depressing the accelerator while starting but had the same results. There is no CEL and my reader does not show any codes. It has happened 3 times in the last 3 weeks. The common denominator has been sub-zero cold on all 3 occasions. The first time I thought maybe I had some water in the fuel, but the symptoms are too similar I think for that to be the case all 3 times. Obviously, I don't feel like I can trust the car to not leave me stranded in extreme conditions. Does anyone have any ideas on where to start looking? Thanks for any help you can offer.
