Ockyb
Posts posted by Ockyb
Today drove to Ikea, 30 minutes, car sat for 35 minutes while inside. Tried to start and only cranked. Turned key off and restarted immediately.
Weather today is close to 50 and dry which contradicts my wet weather theory.
It's a 15-20 minute drive
Originally it was repeated, but they claimed to fix with main relay recall replacement
Today was in the 50's here, didn't have any issues all day. Not sure if that's a coincidence or the weather is playing a factor.
Previous few days were much colder and yesterday was very rainy
With the car having such low mileage, they were hesitant to check fuel system. They seemed determined it was electrical, hence the ecu flash.
I will keep updated, thanks for input
No check engine light
Once started, runs great, gas mileage is phenomenal at over 40mpg.
I can hear fuel pump activate when turning key and will try to see if priming will eliminate issues.
Thank you for your quick response
2015 legacy, 24k 2.5 Premium
Car starts cold without issues
If run to store and restart, takes a few times to start. Cranks but doesn't turn over. Does eventually start.
Recently had main relay recall completed wth-68
Also they completed following update
11-162-16
11-162-16R
Since taking in for the previous stated recall and update, I've had the same issues. Rafferty Subaru didn't have issues starting while in their shop.
Anybody have similar issues?
6th generation Legacy Intermittent Extended Crank
Posted
Has been at dealership for 2 days
1st diagnosis
Replaced crankshaft sensor
Still continued extended crank when hot
2nd Diagnosis - low fuel pressure
Replaced entire fuel pump
Picking up tonight
Thanks grossgary for your insight
