TheMemeMachine
Everything posted by TheMemeMachine
  1. I figured out what was wrong. This morning I pulled the crank position sensor and cleaned it. While putting it back I noticed that one of the tabs on the crankshaft sprocket was broken off (must have done it when I pulled it to change the oil seal). Couldn't find a new one, went to the recycling yard and got one. Put it on and it purrs like a kitten now.
  2. I'm in need of help. I have a 1996 Legacy GT with the 2.5l motor. I changed the front camshaft oil seal and the timing belt. During the process things got out of wack. The engine will start and seems to run fine on fast idle (2500-3000 rpm) for 15-20 secs. Idle drops (below 1000 rpm) engine starts running rough and spitting and sputtering. I try giving it gas and it won't rev up and dies at that point if I don't shut it off first. All timing marks are in what I think are the proper positions according to the diagram that's posted all over the internet and in the Haynes manual. Problem is the marks on the belt and the marks on the pulleys and on the cover won't line up perfectly, like it shows in the diagram. I don't know if what's happening is a result of the timing belt being off by a tooth or if I bent the valves at some point. Can someone please help? Other info there is compression at least in the first cylinder. Have changed spark plugs, plug wires and pcv valve.
