Will any Impreza Suspension/Brake parts fit my 88 GL 4WD Hatch?
Ok so we got in a big symantic war. Now that is with can you tell me, will the 1990 legacy rear axle fit on my 88 wagon, non turbo 4wd 5 spd?
Ok so is it EA81 or EA82
It's a wagon with a hatch
Ok you asked if it had a small or big window but then didn't say which is which. My 88GL is a four door with a hatch, the window is half the hatch. So what would that make it?
88 GL Hatch 4WD/90 Legacy AWD parts compatibility...
Thank you, that's what I plan on doing. Now to find the parts.
What about the Transmission? Will the one in the GL fit in the Legacy?
I've got an 88 GL 4wd Hatchback that needs rear axle parts and a 90 Legacy AWD that needs a transfer case. Both are 5 speeds. Are any of these parts compatible?
Lol sorry Legacy, was looking at pictures of Imprezas.
Actually I have close to the same question. I have an 88 GL 4wd Hatch and want to know if any rear axle parts from a 90 impreza sedan AWD will be interchangeable. My rear left bearings went out and most of the left axle needs to be replaced. Not sure on on the terminology concerning Subarus but everything from the hub to almost the drive shaft needs replacing.
dragonlee2
