TetonDon
  1. Haynes wire diag. Showed a circuit from CPU to power circuit box? To most of the issues I have, hazards work, no power to back of turn switch I found list of codes if you want
  2. Found turn sig. Bulb sockets had froze, flat ting bulb contacts to the point of grounding on socket walls
  3. Thanks for responding,it started when I put on directionals,speed& tac zero out, came back in seconds after canceling , after 4 times, no blinkers , warning lights no charge, I've hooked alt exciter to bulb to power so it charges, will get codes, I know one was no power to diag. Plug . Checked all basics, good poss ign relay, don't know where that is
