Dadsbrat
Everything posted by Dadsbrat
  1. On my 83 brat I have been having problems with my clutch cable it ether breaks or seems to stretch. I have change the brand of cable just not sure/ I was thinking about a hydraulic clutch anybody there thought and recommendation thanks Craig
  2. up date Put new Weber carb. on and run very good
  3. Well I have been trying all day I check coil distributor it seems to be fine,I pulled the top of the carb. check the float and raise the level a little it started up and ran but to much fuel going in the carb. adjusted down a little would not start carb is off and apart little dirt nothing that should keep it from running ????????????????
  4. Thanks but the distributor was change out to electronic back when my Dad had it
  5. I have change both fuel filters and as asking my dad he has pass away the resin I have the brat
  6. My brat has been running good the bad I will go though everything adjust and then it seems fine and then on another day crappy again. What it dose it act like it is starving for fuel once it warms up it ran good ??? The other day I took off it started spitting and sputtering and then died it acted like fuel pump I change it in the poses I discovered groves in the distributor cap. After market crap got one the fit better was able to get it to run like a top in the driveway took off down the road in just a little bit it started spitting and sputtering and then died would not start after that. Has any body experience any thing like this?????????? I would hate to let my Dad brat die after he had it from the beginning and passed it on to me Craig
