Weeza
Everything posted by Weeza
  1. Using synthetic oil helps a lot for residual on components between running the engine. But, since Subaru just settled a huge lawsuit not so long ago regarding breakdowns at lower mileages, I guess the engineering factor isn't as comforting as it once was. We traded in an Outback with less than 70,000 miles that had the defect named in the class action settlement. Do you know of a company that produces custom ECM's for Subaru's? My husband is an engineer, also. He owned repair shops most of his life. He has not only had to repair and rebuild engines, transmissions, etc. that failed due to engineering design flaws, but had to re-engineer to prevent a repeat failure - in other words, if you go back with the same mentality that created the problem, you still have the problem. Auto manufacturers will use a teflon seal in a transmission (instead of a metal one as in years gone by) to save a quarter of a quarter of a cent, that causes the whole transmission to fail. This answer doesn't work for someone that's had to correct engineering design flaws for 30 years.... Having an engine with high rpms, like 2K rpms, before the oil has circulated will definitely have an effect on components. No way around it! And, if the engineers were putting out pure quality with no design flaws then there wouldn't be hundreds of TSB's... to correct problems, and there wouldn't have been a class action lawsuit against Subaru! The Subaru service manager told me it was not possible to change the cold-start idle rpms... And, manufacturers have been known to produce components that will "last the length of the warranty." Thanks for your answer....
  2. Would like to lower rpm's at cold engine start. Our 2016 Crosstrek is set at WAY too high rpm's at cold engine start. This means engine is too high rpms with no engine oil circulation. I KNOW ALL ABOUT THE SUBARU "ANSWER" being that the engine is set to idle high at cold start to lower emissions... and the Subaru dealership refuses to adjust this rpm, even if we offer to pay for it. OK, so I looked up the ECU programming tool J-2534 that you can use with Subaru software... but want to know if anyone has used this tool to lower the cold-start engine rpm's.... OR if there is a company out there that sells custom-modified ECU units, OR that will reprogram an ECU if we sent it to them. Thanks - my husband is a master mechanic, life-long, so knows engines inside and out - we just want to lower the rpm's down during cold start. What you have here is an engine running at extremely high RPM's when there is NO OIL CIRCULATING IN THE ENGINE. Yes, they might achieve lowered emissions but it is at the cost of the engine life - Weeza
