Ok Here is the Low down on Doing the Duel Range swap into your Legacy Sedan.....
You will need a Hi-Lo 5 speed out of an 85-90 Non-Turbo GL Wagon....Converted to Turbo axle stubs in the final drive to Mate to your factory Legacy Axles.....This Gives you 3:90 gearing with the right stubs.....
My Adapter Plate Which Comes with a Custom Done Flywheel, Meaning you Lose the stage 2 ....
You will Lose AWD ability, meaning you become front Wheel drive and Locked in 4WD....
Now hear is the part you didn't hear So well in Burn Out mode that nite in the Garage.....
I can Have one of these Hi-Lo trannies Gone through And have the Turbo stubs added into it as well as a Phantom Grip LSD.....
This will give you 2 tires spinning in Front wheel drive Mode and 3 in 4WD mode in slimy/slippery conditions.....
Add an LSD in the rear Diff, and in snow, ice , or Mud you can potentially have all 4 Locked up and Working for you....
To do this Trans Overhaul your Looking at about 750.00 But it will be Fresh, and Have LSD ,And as a package Deal with the Adapter Kit, I'd Do it for 1000.00
You'll Be the First......or Maybe second if I get the Local Forester Done first...
Let me know......John
P.S. I got your Package thanks....
And My newest Cell # is in My sig here at the bottom......
This is my first post to this board! I currently have an airboat with an EA 81 blown engine. I would like to repower with an EJ22 series from a donor car. I need an adapter to adapt the EJ 22 engine to my belt reduction case, EA 81 transmission pattern, 84-85 GL-DL. I won't need a flywheel as I have what is needed. Where can I get the adapter? Help please, need to get the airboat up and running before warm weather. Again, the adapter plate is all I'm lacking. If anyone could steer me in the right direction I would appreciate it. Email me at jeanie_home_1@hotmail.com with the details. Many thanks in advance for alll your expert help. I look forward to reading the message boards here for more Subaru info.
dual range coversion for an AWD '95 legacy
in Off Road
Posted
