No spark on 2005 Forester sometimes
Chaid replied to Chaid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSolved! Almost. This evening I tried probing the ignition coil input wires for voltage with a multimeter. I first removed the Duralast igntion coil (the culprit). I turned on the car to the on position (not running), and the voltage was 24 volts from one of the pins to ground. I was surprised that it wasn't 12 volts, but it had voltage at a common value, so close enough. Two other pins were at 0 volts with the engine off, but flickered between 0 and ~24(?) volts when cranking: the expected response. On the '05 Forester there is a 4th pin on the ignition coil pack, which I believe is signal for the built-in igniter control module. I also checked the resistance across the OEM coil pack and the Duralast coil pack. Around 11.3 k-ohms for each loop on the OEM and 10.5 k-ohms on the Duralast pack. In the service manual, the spec is 12.8 k-ohm +/- 15%, so this resistance really shouldn't be below ~10.9 k-ohms. I put in the original OEM coil pack. It now starts every time! However, the first time I started it up it was shaking around a bit as if one of the cylinders isn't firing correctly. I somewhat expected this because the old plug contact was ripped off and lodged in the OEM coil pack socket and I had to drill it out to fit in the new plug. After shoving the plug in a bit more and driving around a bit it wasn't so shaky anymore. However, I now have a steady check engine light and the green cruise control light is slowly flashing. I am going to go have the error read since I don't have a reader and will report back with the code and the fix once I know more. I am anticipating that I will need to get a new OEM coil pack most likely. Also, we will see if the initial stalling problem returns or if the replacement wires fixed that. Fingers crossed. Will need to wait for rain for that to happen, perhaps this Wednesday it should be warm enough for rain here. Don't use Duralast ignition coil packs for Forester! OEM only!
Chaid replied to Chaid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI hopped in this morning to see if I could get it running. Still no start. I listened for the two clicks from the main relay and could hear it every time. I am going to try probing the ignition coil pack when I get home from work tonight to see if I am getting 12v where/when it belongs and will post results. I want to see if the Duralast coil is giving me the issues or if it somewhere before there. I still have the original pack handy so I can try it out, but I will need to drill out one of the connectors as the old plug connector is jammed in there. So far, I have tried all manners of starting: straight on, short bursts, stepping on pedal a bit to let air in, stepping on brake to jog safety mechanisms. I will try jiggling around the shifter (auto), but I have found that this failure typically prevents the engine from cranking in the first place, so I don't think this is it. Not sure if the timing belt (and other applicable service) was performed at 105k miles as I bought the car at 162k miles, so perhaps this could be it. @bstone, your issue sounds a lot like mine! Does anyone know if 05 Foresters have a separate igniter from the coil pack? Having trouble finding any references to this online.
Hello USMB, I have a 2005 Forester with 172k miles on it in Boston. In October (3 months ago), I was having some issues with the engine stalling when it was rainy out. I could get the car driving, but once I would get up to ~2500 rpm in the rain, the engine would sputter and lose a lot of power. To fix this problem, I changed out the ignition coil and the wires to the spark plugs. I used Duralast parts for this. This seemed to fix that problem, but a new problem arose. Since swapping the coil and wires, the car will oftentimes not start. It will crank and crank, but will not start running on its own. In cold weather (less than 20 degrees F), there is not really much of a chance it will start. In warm weather, it will start sometimes. Hooking up jumper cables to another car would help sometimes, but not always. I have since replaced the spark plugs and cam position sensor (1 of 2?), which didn't help at all. I had the car towed over to a mechanic who tried diagnosing it for the last two weeks. He discovered that when the issue was happening, there was no spark. However, he could not figure out what the issue was. He replaced the crankshaft sensor, but that did not help either. In week 2 (last week) of the car being in the shop, the car was starting up every time. I picked it up and drove it home with no problems since I need the car for work. Ever since then (2 days ago), I am having the same issue again and have not been able to get it to start a single time. At this point, I am thinking perhaps it is the wiring or the connector to the ignition coil, the ECU, or perhaps another sensor. Before I try poking around in there some more, I am hoping someone here might have some advice on this case.
Chaid
