![](https://www.ultimatesubaru.org/forum/uploads/set_resources_9/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
Kraven
Posts posted by Kraven
Right,that's the A/C condensation drain.....just let it hang.
Yup, do have air con
Thanks
If it's a large diameter hose it probably goes to the "trombone" pipe at the top of the intermediate pipe (longer mid-pipe) just rear of your tranny.
Its about 1/2 an inch or more in diameter, and maybe 6 inches or so is coming out of the body work. Will have a look for that trombone pipe and see if it goes there.
My subu is carborated
Thanks for all the help this board is great
Please forgive my mechanical ignorance, I did take mechanics class back in high school but it was a long long time ago
Your Y pipe should have a small tube rising up from around just before the cat.on the passenger side.One end of the flex tube goes on there...other on the airbox...you know the deal.
Hi again
Ive found a rubber pipe in that area which isnt connected to anything it blows air when the engine in running is this it?
thanks
Hi
Been meaning to ask about this for a while now. The hot air pipe is not in good shape, busted in quite a few spots and not connected to the stove pipe. What kind of problems am I likely to run into and assuming I buy a new pipe where is the stove pipe that its supposed to connect to, I cant figure it out from my haines manual.
86 gl wagon
Thanks
Hi all,
Its fixed, I moved the trunk hook a little further back and of goes the light when closed.
Thanks
Hi, I own a 86 GL wagon 4WD. The car appears to have a small leak, not sure where its coming from but it seems to be dripping of the steering gear boots, or around that area. The leak isnt much but im a little worried Im keeping an eye on the fluid levels and so far everything is ok, any advice?
many thanks
Hi, I own a 86 GL wagon 4WD. A few weeks back i got rear ended, not much damage but it did force the trunk in an inch or to and made it hard to close. Ive since managed to push out some of the dent and now it closes nice and easy but alas the trunk indicator light is always on. I cant figure out where the switch is, any ideas how to fix this ?
Thanks
Wheel nut problem
Posted
Hi
One of the huts on my passenger side rear wheel has damaged the bolt when i was having some new tires put on. The other three are fine. Question is how big (and expensive) a job is it to get that bolt fixed?
thanks guys
