I used an led light, you can see it blink, looking closely. Hot to battery, negative to injector wire. (Led polarity matters)Tested with working injector, then number 1, was no blinky
Two things.. adding power should not and will not open injector, adding ground would.. but don't, you're shorting ecm.
Instead of buying new ecm, solder board where injector wire pin is on it..
They wires all have black sheathing in last plug, easy to find..
Much cheaper, fixed as soon as you melt cold solder joint, slit second.
Update it was actually this IC. SOLDER all connections.
misfire on number 1 cylinder '06 Tribeca, H6
Posted · Edited by Druboi
Was wrong
I had number 1 missfire..
