Everything posted by markjs_pnw
1984 GL Wagon 4wd needs radiator
Well new, nobody beats Autozone at $125 Though could be core charge unincluded makes rock auto $200? I guess I should go new ut it's a huge hit.
Well I ordered the junkyard part for now. I did make an inquiry about having one built for it. I bet it's not the first request for this they've had.
These EA81s must be low friction. I never even overheated. Got close to the red but each time the thermo would open and it coooled off. I noticed because the heater stopped working. Anyway, engine is fine, but now I definitely need a radiator. I'm nervous about wrecking yards, do they check for stop leak? In any case it lists locally (the cheapest) for $270 and $125 out of town at Autozone. I'm of limited funds, so the so called "grade A" junkyard part for $50 seems a lot more affordable. Is it worth the risk? Also, what all year and models have radiators that will fit? IIRC the EA82s were bigger and were part plastic (which I don't want)?
1984 GL Wagon 1800 starting problem
The passenger side of the carb is all greasy? Problems with PCV or? Never seen such a nasty greasy mess on a carb? Gonna hit it with degreaser tonight maybe, check the power.
Something super odd happened this morning; it was very cold, so I warmed the engine up a bit to get the heater going, but when I went to move it died. Then I couldn't get it to start at all unless I floored it, and it wouldn't really run till I reoved the air cleaner top, it still needed the pedal floored but I eventaully got it to rev up and run right after a second or two. I guess the old Hitachi is getting tired. I'm assuming it has an enricher, not a choke? thinking it got stuck. Anyway the carb looks complicated, but is it that bad to rebuild? Unfortunately I think this might be my best option, but until I can, I got to get this Hitachi to get me by
Can't keep idle down on 84 GL 1.8 with Hitachi
Passenger side of carb or drivers? I'm intimidated by my otherwise nicely running Hitachi, lol
I set it about 800RPM but no matter what most of the time it ends up stuck at 1200? What's sticking and how can I fix it? This car needs hardly any warm up, engine runs beautifully except for that.
1984 GL Wagon 4WD Fuel Pump Problems
First the ancient pump died, but the replacement Edelbrock stopped pumping too. I think it may be one of the electrical relays that makes it only work when the engine is running, or the starter cranking. i don't have a Chilton, can anyone tell me where those are physically located on the car in case they need replacing? (1984 GL Wagon 4WD) Thanks.
