Everything posted by Subaru45895
Valve Guide
This is a 90 Subaru legacy 2.2 engine. One of the valve guides is about .125" lower than the rest. Should I be concerned? It was not burning oil before I took the head off to replace head gasket. I noticed it while installing new valve seals. It doesn't look look like it has ever moved, no marks on guide. I am thinking about letting it go. What are your thoughts?
Valve Springs
Is there a top and bottom to valve springs? I didn't notice any difference in the spacing of the top and bottom spirals. I own a 90 Legacy 2.2. These are stock valve springs. Thanks!
Oil Pump
Do I need to put a sealant between the pump and the backing plate on oil pump? I will put loctite on the screws which hold on the plate. Thanks!
Speed Sensor 2
Subaru45895 replied to Subaru45895's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks Josh for all the help!! Dan
Speed Sensor 2
Subaru45895 replied to Subaru45895's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is good to know when it is cold out. What is the easiest way to check speed sensor 2?
Speed Sensor 2
Subaru45895 replied to Subaru45895's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi Josh, The car has an automatic transmission. Sometimes it would hold in third gear to long. That would happen only when car was first started. Then I noticed while turning right that the right back wheel wanted to drag around the corner. After all of this happen, then I got a flashing power light on dash after starting car. I checked the codes and that is when I got code 24 & 33. Thanks, Dan
Speed Sensor 2
I own a '90' Subaru Legacy. I checked the codes on the transmission. The Speed Sensor and Solenoid C codes appear. Is it possible if the Speed Sensor is bad that I would get a false code for the solenoid? What is the easiest way to check the Speed Sensor 2? Thanks, Dan
Transmission
I own a 90 Subaru Legacy LS. I checked the codes on the transmission. The error codes are 24 and 33 (Duty Solenoid C and Speed Sensor 2). Where do I find these on the transmission? Is there a website that I can get a pdf file with pictures to show location? Thanks, Dan
