timh58
  1. loogic23, I have had all 4 wheels off and the sensors appear to be whole and straight as soon as I have a chance I will ohm the sensors out. 3Pin my light is on continuously and it doesn't matter if thee car is in P, R or D but thanks for your input.
  2. Thank you John I thought it looked like that was where the cable was going and was hoping it wasn't long enough to go all the way to the front. Now I'm sure where I have to go to ohm the two rear sensors out.
  3. Thank you and the ABS light is on all the time and I can't pull a code for the brakes at all. I do appreciate the advice from both of you.
  4. The man I bought it from said his mechanic told him it was a sensor. I have had all 4 wheels off replacing wheel bearings and broken and damaged wheel studs and I didn't notice any damage to the exposed wiring.Is there a way to test the sensors and do the sensors on the rear wheels plug into something under the rear seat?
  5. I have a 1995 Subaru Legacy LS and the ABS light is lit. I was told it is because I have a bad ABS sensor on one of the wheels. How do I find which one is baad?
