I'm removing the right-front axle on my 96 impreza brighton tomorrow and I just wanted to check on a few things.
1) How do I kow which direction to knock out the pin that holds the axle to the trans? One side appears to be flush, the other isn't.
2) Should I removed the pinch bolts above the steering knuckle or remove the A-arm from the engine crossmember and the sway bar? These are the two most common methods of removal right? Would I have to compress or hold the spring? Do I have to loosen up any or the strut assembly?
3) Also, is it a 3/16 in. drift to punch out the axle pin?
4) order goes something like, 1) pin, 2) steering knuckle or a-arm, 3) remove axle from tranny, 4) get a big hammer and knock out the axle from the hub, 5) pray the bearings stay put, 6) stuff in new axle
Any other tips are appreciated. I've got the car on stands and I've been soaking the bolts and pin for a day now. Thanks.
