Jsub
  1. So an update: i did put the car in Neutral (moved shifter side to side) it started.. it also shot these codes
  2. On the old battery I replaced like 5 months ago.. tons of fuzzy corrosion on mainly positive. Maybe bad positive post terminal?
  3. What would be clicking in or near glove box during multiple clicks when I turn it over?
  4. There has been times when I’m driving the security alarm light is still flashing. With in the last 2 months only on occasion.
  5. These cables look like dinosaurs honesty...the crazy thing is I used to be able to wiggle the shifter in park. And it would go from no crank no start to starting. But now no such luck.
  6. Ok I am stumped.. I have a new Battery. I went out for a couple of hours came back home then went to start the car a few hours later .. nothing. Checked fuses, tapped the starter, lights are bright not dimming, radio works, blower motor fine. I turn the ignition to turn over: I hear multiple clicks ( like a wood pecker) also hear clicking in glove box. I tried turn car over in different gears too... Nope. So I left key on after I tried turning over all items on dash cluster are on I put shifter in reverse ( key still on) constant buzz under hood until I put back in park. Then it buzzing stops. Put back in reverse buzzing stars again. Any ideas ? Thank you in advance for any tips.
