Jsub
Posts posted by Jsub
On the old battery I replaced like 5 months ago.. tons of fuzzy corrosion on mainly positive. Maybe bad positive post terminal?
59 minutes ago, 1 Lucky Texan said:
double check battery cable connections. Charging circuit probably needs testing too.
has there been a history of lots of fuzzy battery corrosion? battery cables can corrode inside the insulation.
try whacking the starter a little harder - use a piece of 2x4 or similar.
What would be clicking in or near glove box during multiple clicks when I turn it over?
1 minute ago, 86BRATMAN said:
Does the security light in the instrument cluster flash or stay on solid?
There has been times when I’m driving the security alarm light is still flashing. With in the last 2 months only on occasion.
These cables look like dinosaurs honesty...the crazy thing is I used to be able to wiggle the shifter in park. And it would go from no crank no start to starting. But now no such luck.
Is that a new starter.. or maybe an easy fix?
Ok I am stumped.. I have a new Battery. I went out for a couple of hours came back home then went to start the car a few hours later .. nothing. Checked fuses, tapped the starter, lights are bright not dimming, radio works, blower motor fine. I turn the ignition to turn over: I hear multiple clicks ( like a wood pecker) also hear clicking in glove box. I tried turn car over in different gears too... Nope. So I left key on after I tried turning over all items on dash cluster are on I put shifter in reverse ( key still on) constant buzz under hood until I put back in park. Then it buzzing stops. Put back in reverse buzzing stars again. Any ideas ? Thank you in advance for any tips.
No Crank no start... 2006 Subaru Outback
Posted
Very good information, I appreciate it! Thank you.
